Bow spot light
- C0ps
- Vessel Info: 1992 carver montego 528
- Has thanked: 3 times
- Been thanked: 6 times
Bow spot light
I don't think it's the switch or else it wouldn't move every other direction. What's your thoughts?
- Been thanked: 1113 times
Re: Bow spot light
On my old one the 'joystick' control would get dead spots, especially if it hadn't been used in a long time. I made a habit of moving the spotlight around to all its extremes as often as I could remember to do it. When I would sense a dead spot, I would move the control around that area more to "clean" the contacts a bit and then it would work fine for a while.
Check the wiring behind the switch too, as well as any possible connections going up to the light. You might have some corrosion on a given connection that moves it to starboard.
You could have some mechanical things going on too, inside the light assembly. Sometimes that grease gets pretty old and cruddy and makes things hard to move. That might require some disassembly and clean up to resovle.
- plittle2005
- Has thanked: 16 times
- Been thanked: 37 times
Re: Bow spot light
- C0ps
Re: Bow spot light
