Breaker bank 1 main breaker and two 15 amp breakers appear to be pined together
- Donh
- Vessel Info: 1999 Carver 406 diesel twin Cummings
- Has thanked: 1 time
- Has thanked: 603 times
- Been thanked: 1311 times
Re: Breaker bank 1 main breaker and two 15 amp breakers appear to be pined together
Anyway, breakers generally have id labels on them......you can check out what they are and get them from Blue Sea.....most marine stores and chandleries carry some popular ones.
Welcome aboard.Donh wrote:Source of the post I have been tripping the salon breaker and main on Breaker bank 1. I bought a new 15amp breaker to replace but it appears the main breaker and next 2 15amp breakers are pined together....
Unless I'm missing something, that doesn't make sense to me. That would not be the norm, and if you're tripping the 3rd and main but the second doesn't trip, then all three can't be pinned together. Are you coming to this conclusion based on what you've seen behind the panel? I can see the main consisting of a double breaker with only one toggle but that's where it should end. Individual circuits should not be physically tied to the main breaker.
Unplug everything in the salon outlets and see if the Main trips when everything else is run on that side. If the main doesn't trip, then your main breaker and shore cord are likely okay and the issue lies with something plugged into a salon receptacle, or an issue with one of the receptacles themselves, or the breaker. It could be as simple as plugging in one thing at a time to see which item trips the breakers again.
Confirm the brand of those breakers. They might be Carling and they are not always interchangeable with Blue Sea units.
- Been thanked: 654 times
Not sure if the pinned together thing is the description below but maybe this is what you meant?
All boat breakers that I am familiar with are tied together with one of the screws on the back to a copper buss bar on the positive side coming off of the main breaker (power supply to the breaker). The other screw on the back gets connected to the load you are controlling.
Most of the time you need to remove that buss bar in order to change a breaker which involves unscrewing each individual breaker where it attaches to the buss bar. Sometime you get lucky and only a couple of screws backed off suffice.
Unless his set up is different, the strip starts on the first load breaker and through the rest on that side, the strip itself isn't connected to the Main breaker. There should be a wire from the load side of the Main breaker to the strip on the first load breaker "REC AFT"Donh wrote:Source of the post......the main breaker and next 2 15amp breakers are pined together.....
Like Hans said, loosen the screws holding the strip on the first few breakers and it should allow you to move it just enough to pull the breaker out.
Make sure you disconnect from shore power and don't just leave the plug lying there on the dock, a passerby may think they're doing you a favor and plug you back in not knowing you're working on the panel. Bring the cord on board. If you actually have an inverter as labeled on the panel, this was an option, you must turn off the DC power to the inverter as well.
- Donh
- Been thanked: 1113 times
Marine main breakers sometimes consist of three actual breakers behind the ONE switch on the front. Two of the breakers are for the AC lines - hot and neutral - and the third one is part of the 'reverse polarity' circuit which WILL (or should) trip the other two if it senses a problem in the circuit. All three are bolted together in one assembly but look like three distinct breakers right next to each other.
