Gap at the Bridge floor by the Helm
RLCLONCH
Vessel Info: 2003 Carver 444
Cummins 5.9 BTA
Postby RLCLONCH » December 20th, 2022, 11:40 am
I have a 1/4" gap that flexes where the bridge floor meets up to the bridge dashboard. How serious is this? What should I do to fix?
Thanks for your help
Ryan
2003 Carver 444
Re: Gap at the Bridge floor by the Helm
Postby Viper » December 20th, 2022, 6:06 pm
Welcome aboard Ryan.
You might have better luck getting an answer if you post the question in a more appropriate section like "General Repairs & Maintenance"
A member with the same model/year might chime in but usually the builds have sections that go together and can be removed for transportation. It may be that it's a seam between two sections you're looking at that simply needs to be caulked. A picture would help determine if this is the case or if there is a structural issue going on.
Users browsing this forum: No registered users and 40 guests
