97 Carver 355 AFT cabin...where is the...
benica
Vessel Info: 1997 355 Aft cabin. 7.4 engines.
Been thanked: 9 times
Postby benica » January 2nd, 2023, 5:46 am
Good day all! And have a great New Year!
Port side...the 3 main cabin ceiling lighs do not come on. SB side and the 3 just below the bow facing windows work.
Am I not seeing another light switch or...need to remove the ceiling panel and do some diagnostics??
Re: 97 Carver 355 AFT cabin...where is the...
Postby g36 » January 2nd, 2023, 8:39 am
Happy New Year to you.
My main cabin lights in my 405 are on a switch by the stairs going out to the sundeck any switch in the area on your 356?. Have you taken a bulb from one of the ones that are working and swapped it into one of the non working lights, that's a easy way to check or grab a volt meter and check for voltage in the lamp socket. I doubt your going to need to remove any panels to get this working.
benica
Postby benica » January 2nd, 2023, 5:46 pm
Yes... checked each already. But 3 not working?? 3 LEDs out...unlikely. Has to be wiring or...switch.
The 355 has the light switch next to the sliding cabin door. So...removed the wall switch...wiring seems OK. Don't want to have to take down those ceiling panels for wiring diagnostics... no choice though.
Appreciate your reply.
Postby km1125 » January 3rd, 2023, 9:00 am
If you have definitely ruled the bulbs out (really, it's not unheard of for issues like this to be just bulbs!), then have to tried just removing the first or last fixture and seeing if that's where the feed comes from? Sometimes they just snap in place, other times there's a screw. Don't know on those specific fixtures how they're installed.
Could be a bad connection at the last good light or the first bad light.
Been thanked: 285 times
Postby buster53 » January 3rd, 2023, 9:57 am
Have you tried the switches next to the stove across from the dinette?
I’m assuming this is a new to you boat? Was the issue noted in your survey report?
