Carver 466 - Portal trim piece and other parts
- David Brady
- Vessel Info: 2001 Carver 466 aft Cabin
- Has thanked: 17 times
- Been thanked: 6 times
Here's to calm seas for all and I leave you with....
my best Regards,
Dave Brady - 2001 Carver 466
Re: Carver 466 - Portal trim piece and other parts
If the outside measurements of your trim ring is 22"L x 11" H, the Pompanette part number should be VT517-1-1/16OW ("White VAC trim for 517") This was for a 2003 466 MY but likely the same unit. You should have them confirm first based on your picture and measurements. Hopefully they still have them.
Keep us posted and if you end up with something else and a different part number, please post it for future reference.
- David Brady
- David Brady
Turns out you were exactly correct on the measurements and part # VT517-1-1/16OW ("White VAC trim for 517")! They confirmed and I purchased 2 at $107 apiece. I'm working on installing them now. It seems that over 20+ years (2001 model) the shower walls have either moved or shrunk, as the gap between the wall and the hull has increased significantly. I don't want to force the wall back to the hull too much and risk cracking everything, so I have bought some longer stainless screws and a pile of stainless washers to use as spacers, and will be finishing the install that way. Let us never "rock the boat"!
Thanks Viper and team!
Dave B
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Interested to know.
Greg
- David Brady
The trim pieces fit great! The install is easy - biggest thing to remember is to not let the Porthole assembly fall out while you remove all the screws from the interior stainless trim ring, which pins the plastic trim piece to the wall. One of my portholes was "loose" when I took the screws out so I held onto it while removing the trim piece. (caulking when resetting).
For the master head, because of slight wall-shifting, I needed to cut a small notch in the top of the trim piece to fit around the porthole hinge - easy peasy with a sharp box cutter. Picture below. For the VIP Head, pretty much done but still casting about for a good looking piece of white(ish) insulation pad to plug the small gap where the wall of the shower doesn't quite come back to the hull. hopefully yours fit perfectly so you won't have to worry about that part. All good, thanks to all for the direction and partnership! Sail on, mates.... good times, never felt so good!
Dave B
Brayde Davies - RI
