Magnetic switches
- mjmason1
- Vessel Info: 1999 Carver Voyager 530
- Has thanked: 2 times
- Been thanked: 19 times
Magnetic switches
- Has thanked: 78 times
- Been thanked: 1093 times
Re: Magnetic switches
Could they (or one of them) be for the glow plugs?
- Sgodfrey
- Vessel Info: Carver 450 Voyager
- Has thanked: 1 time
- Been thanked: 9 times
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 143 times
- Been thanked: 134 times
My aftercooler ones were burnt up also so I pulled the aftercooler heater fuse to disable the whole system - it looked like it was a fire waiting to happen! After running the boat for 6 months with no discernable difference, I removed the entire system (mag switches, wiring harness, etc) which just cleaned up the whole area of the engine a lot!
Now if you are up north and routinely run the boat in the winter, that heater definitely helps with starts! But an oil pan heater will do the same with a lot less wiring. Since we stay away from the cold I have found no impact removing the system.
As mentioned, a lot about this can be found on the SeaBoard Marine website which is where I found out about disabling/removing the system if it is unnecessary. YMMV.
2002 Carver 396
