Spark plug wires not matching up to diagram
- Ctmangrum
- Vessel Info: 1977 Carver Mariner 2896
- Has thanked: 37 times
1976 carver mariner 2896 Ford 351m
- Has thanked: 603 times
- Been thanked: 1311 times
Re: Spark plug wires not matching up to diagram
What rotation engine do you have ?
- Ctmangrum
- Ctmangrum
- Been thanked: 1113 times
THEN you can trace that wire back to the distributor to tell which post on the distributor corresponds to #1.
You can check distributor alignment by putting the crankshaft at (or slightly before) TDC for #1 and then pop the dist cap off and see which way the rotor is pointing. It should be at the post where the #1 spark plug is connected.
- Ctmangrum
Tip.... Don't mark any wires or boots directly with magic markers/ sharpies....they can conduct electricity and lead to problems.
- JimN
- Vessel Info: '89 Carver Santego 38
- Been thanked: 3 times
If you removed the plugs/wires/cap and then rotated the crank, you'll need to find TDC for #1- look on YouTube for videos on how to do this without buying a timing disc.
- Ctmangrum
