Carver 466 - Davit Madness......
- David Brady
- Vessel Info: 2001 Carver 466 aft Cabin
- Has thanked: 17 times
- Been thanked: 6 times
Hope everyone's on an even keel this morning (or leaning in that direction). Purchased my '01 466 at the end of last season. One of my biggest peeves-of-the-purchase was that I was "mis-informed" about the electric davit system (there is no electricity involved!). I have the "swing the ding up" variety pictured below, which doesn't suit me as a) whenever it's there, the swim pad is practically useless, b) even without the engine installed, the thing is a bear for this old coot to pull up (minimally getting a come-along or block-over to assist) and c) the current 15 horse motor weighs over 100lbs by itself, so removing it and installing every time I need to stow it is a non-starter.
I have investigated a couple of good looking options for easier, relatively inexpensive systems including this under-mounted extended Davit System (https://www.dinghydavits.com/products/u ... 2630958264) from Dinghydavits.com and this out-rigger system from Binnacle.com (https://us.binnacle.com/Docking-and-Moo ... escription). I was told by my Marina team that the under-mount system is not a good option for the swim platform on my boat and they are evaluating the second option and will give me feedback and a price shortly.
In the meantime, what do others have for Davit systems? My preference is to have something that allows my to store the dinghy horizontally, above the wake without paying thousands. If anyone else has any good ideas I would greatly appreciate the feedback. Looking forward to hearing from everyone!
Here's hoping that all stay above the waterline and have a great day ahead!
Regards,
Dave B
508-254-4097
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 138 times
Re: Carver 466 - Davit Madness......
I have the same issues - looking forward to the replies!
2002 Carver 396
- Been thanked: 1113 times
There's also an option with the kind of system you have to mount the engine on a pivot, so the engine stays vertical as the dingy is pulled up to the 90 degree position. Had one friend who did that and he liked it.
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
for the swimming swinging the whole contraption to a side would free a part of the platform.
But the outboard... that's a heavy problem. Don't quite understand how it could pivot without getting stuck against a floating side.
that dingy has been in the water for very long it seems, so the solution was not used much, with reason obviously.
in fact the dinghy pivots and turns 90degrees. would be smarter to have the rods and hinges such that the boat lifts up and pulls horizontalle to the boat. Like a paralell hoist, a shovel, a motor stand. Seen some pretty expensive and complex systems here so its worth getting creative with.
This is one of the systems:
https://www.weaverindustries.com/index. ... nghies.htm
This page has several dingy davit systems discussed, and they cover the "pivoting motor" in there too:
https://www.lifesaport.com/home/2017/11/9/dinghy
- Has thanked: 602 times
- Been thanked: 1311 times
David Brady wrote:Source of the post In the meantime, what do others have for Davit systems? My preference is to have something that allows my to store the dinghy horizontally, above the wake without paying thousands. If anyone else has any good ideas I would greatly appreciate the feedback. Looking forward to hearing from everyone!
Heh Dave......considering you will be ocean/rough water boating at some point IMO there is only a few ways to go to be safe. By safe I mean your back, the boat and the dink itself. None of these are cheap.
You need to get the dink well out of the water to avoid any following sea issues and I believe your boat digs a bit at the stern. Don't let anyone say they are fine with the dink sitting on the swim step, it only takes one bit of bad luck. In my experience the davit crane in some form is the best solution for the stern or on the bow. They are easy to operate, electrify with a winch motor for ease of use and you will have the use of the platform when the dink is deployed especially with your boat design.
There is also something called a Dinghy caddy which I found to work real well, the dink sat level with the engine on, gas tank in and well out of the water, puts the load point ( weight applied to the boat ) a bit more forward as well.....also easy to electrify with your boats aft design. We used one for years and were very happy with the design and ease of use, and we had a transom door to get thru.
Good luck with your search....
- Phrancus
- Contact:
all clear now.
km1125 wrote:Source of the post Here's a couple links that would explain my "pivoting the motor" comment.
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
To do it right would not be cheap and it is worth spending the money. There are lots of options out there.
I was able to purchase a used Sea Weed System that was designed for a boat like mine, that I really like. It was designed to allow the dinghy to be cantilevered off the back of the platform and raised high enough so the water cannot come in contact with the dinghy. I have a 12 foot Highfield centre console with a 30 hp on it, (530 Lbs)
Another really good option for you is the Dinghy Caddy, as stated by Bud37. You can check out their web site dinghycaddy.com and get a sense as to how the works. This is a Canadian company and it is used by a lot of folks. Your money will go a long way.
I used the weaver davit system like you have now when I bought my boat with a 12 ft and a 9.9. merc. It was a challenge to get the dinghy up so I purchased a DC powered winch that attached to a high point on my boat with a "D"ring, to get a good angle, which makes it a lot easier to pull up. The only issue I had with this system was when I was in big water, 10-12 ft swell that was hitting my seaboard side. The water was hitting the dinghy broadside due to its position on the system with so much force, that the pad/yoke let loose and the dinghy was last seen floating upside down in Georgian Bay, to be found later on the rocks in the Bustard Islands by the Coast Guard. I did notice that you do not use the adhesive pad/yoke to secure the dinghy on the front. Thats a good move.
Hurley also has a great davit system, however you will not have enough platform to use that one unless you extend the base. I have seen some folks build a large base with layers of starboard. I have a picture of this set up that I will search for so you can see it if you would like.
Not sure about the type of boating you do, but some folks that don't deal with the locks up here just tow their dinghy with a proper harness with three points of contact at the dinghy and two at the boat.
It will be difficult to get full access to your swim platform with most solutions, unless to go with a Freedom Lift or something like that. $$$$$$.
Good luck with your search, happy boating.
Greg
- Y2K996
- Vessel Info: 1996 Carver 500 Cockpit Motoryacht 420HP 8.3L Cummins. 3 bedroom 2 bathroom layout. Enclosed flybridge and aft deck with 5 air conditioners. Available for charter in the Sarasota to St. Petersburg area.
- Been thanked: 3 times
- Contact:
https://www.yachtworld.com/yacht/1996-carver-500-cockpit-motor-yacht-8587811/
- David Brady
Users browsing this forum: sdsurf and 34 guests
