Redundant breakers for engines
- Marooned
- Vessel Info: 1989 Carver 3467 Santego
Repowered 2005 with two 5.7 MPI Crusaders - Location: Huntersville, NC
Thanks for your help.
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
Re: Redundant breakers for engines
- Has thanked: 602 times
- Been thanked: 1311 times
If so that does not seem on the surface to be something original to me anyways.......Phrancus is correct.....people do some things over the years..
- Marooned
Yes, both engines are working / operating as they should. The tie bars connecting the breakers together appear to be manufactured for this application. That's what I meant by it looking as if it were done from the factory. I read (somewhere) that this was to obtain an ampacity of 120 amps and was, by code, only permissible through the manufacturer. That doesn't add up to me. Through my knowledge, even paralleled, you only have 60 amp capacity.
I have ordered two new breakers. I will separate the circuits and protect them independently.
One thing I have failed to mention....I have owned this vessel for four years and there are a few things I have noticed. One, Carver Yachts built a very sound vessel that can stand the test of time. Two, we as owners are bad to "rig" things. I've spent a lot of time putting things back to manufacturers specs that were rigged poorly.
Thanks to everyone who spends the time to keep these classics safe and allows us to enjoy the water.
- Marooned
I've not forgotten about my issue concerning the tandem breakers. I've just been busy at work and haven't spent any time running the circuits down.
I've been pondering this in my head. The two breakers in question may not be supplying power to the engines. It could very well be the two circuits leading to the breaker panel in the salon.
I'll figure it out one of these days and when I do I'll post my findings.
