Installing fives elliptic portholes.
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » March 25th, 2023, 7:14 am
I got some fixed elliptical porthole windows (Bomar/Pomponette) from great Lakes Skipper. the original ones were getting tired in sealing from water. NO instructional sheet. I called Pomponette and they have none except a generic sheet of use a quality marine caulking between surfaces, single sheet. So i toss this out to you all.
There are a window pane, inner ring, outer ring and trim ring. By playing with these, I came down to this:
Install inner ring first, so it is caulked and go though the hull. It fastens with the tabs, so I would say pull back the rat fur to fasten.
Install the outer ring that slides over the inner ring that protrudes. Caulk around edges, and also around outer ring so when pushed in to the inner ring, all surfaces meet against sealant.
Place porthole on the outer ring against the rubber seal.
Place the outer trim ring on top of porthole window, then when fastened, the trim ring screws will go through the trim and outer ring.
Pics below, and all comments welcomed!
Best,
Tony
tonyiiiafl
Re: Installing fives elliptic portholes.
Sorry for the FIVES in title. Haven’t a clue!
markalexander
Vessel Info: 2006 Carver 42 Super Sport
Has thanked: 31 times
Been thanked: 3 times
Postby markalexander » October 27th, 2023, 6:10 pm
Thanks for all the photos and great details it's very helpful
I want to replace our fixed oval windows in the main bedroom at the bow with opening oval windows on our Carver 42 Super Sport
I'll keep searching this forum to see if anybody else has done this but really appreciate your detailed explanation and the photos :-D
Users browsing this forum: No registered users and 72 guests
