Gas engine tachometers
- MyPleasure
- Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
- Has thanked: 2 times
- Been thanked: 23 times
I guess that the first thing to do is to check the wiring of the lower station tachometer and compare it to the bridge tachometer.
Anyway, if anyone has had this problem, any information would be much appreciated!
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
Re: Gas engine tachometers
- Has thanked: 603 times
- Been thanked: 1311 times
- MyPleasure
Thanks again fellas, you guys are always great for information!
- MyPleasure
Well, I switched the tachs on the bridge, and the good tach worked on both engines, but the bad tach didn’t work on either engine. I’ll try playing with the 4-6-8 switch and see if that fixes the problem. If that doesn’t fix the problem, then I’ll pull one of the tachs from the lower steering station since we never run the boat from there. Last resort will be buying a new tachometer, if I can find one that looks the same as the original tach.
- MyPleasure
I did try playing with the 4-6-8 switch, but no luck. I swapped out one of the tachs from the lower steering station and installed it on the bridge, and it works great! I never use the lower steering position anyway, so it works out OK! I might take the bad tach out again and play with the 4-6-8 switch a little more, but in the meantime, it’s sure nice to have both tachs working again. The port bridge tach hasn’t worked since we bought the boat.
Can anyone explain to me how to upload pictures on this sight? I’ve tried a few times, but still no success!
- Been thanked: 1113 times
