Replacement 12v breaker switches.
- Hoplite808
- Vessel Info: 1988 Carver 3227 Convertible
- Has thanked: 1 time
- Been thanked: 8 times
Or has anyone done a nice upgrade or improvement to the factory design that they would care to share?
Re: Replacement 12v breaker switches.
https://www.digikey.ca/en/products/deta ... id=6041293Here is some documentation on the "Airpax Snapak" stuff. https://www.verical.com/datasheet/sensa ... 989461.pdf
10A = T11-1-10.0A-01-20A-V
15A = T11-1-15.0A-01-20A-V
20A = T11-1-20.0A-01-20A-V
Ordered them on line from a large electronics supplier in Canada but they should be available from a US supplier too.
- Has thanked: 602 times
- Been thanked: 1311 times
Amazon, chandleries, local marina parts, west marine should have common breakers.
- Hoplite808
bud37 wrote:Source of the post Blu Sea systems has breakers to replace those I believe.....that is what I have used, just need the right one to fit the panel though.
Would you happen to know the blue sea part number? The Airpax ones are almost $90 US each.
Why are you replacing, did a test reveal it failed?
Hoplite808 wrote:Source of the postbud37 wrote:Source of the post Blu Sea systems has breakers to replace those I believe.....that is what I have used, just need the right one to fit the panel though.
This is the replacement I was talking about....check out the link, it has all the sizing and will just require two small holes to mount, if like I said it fits in behind the panel. Just choose your amp needs unless you have to have exact match.
For a little engineering, ....Darn sight cheaper than 90 USD,,,, wow thats nuts for one breaker. My opinion anyhow.
https://www.bluesea.com/products/7206/A ... le_Pole10A
