Throttle cables stiff, but only when under way?
- drewp
- Vessel Info: 1996 325 Aft Cabin
- Has thanked: 12 times
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Throttle cables stiff, but only when under way?
- drewp
bud37 wrote:Source of the post Have you watched the engines while underway to check for excessive movement ? Seems to me that if they are smooth when off the cables may be fine unless something is flexing.
I do not believe the engines are moving much at all - I will confirm the next time I take the boat out. Thanks!
- drewp
Viper wrote:Source of the post Is it original equipment or has there been an upgrade to fly-by-wire controls? Do your cables go from the engine all the way to the helm controls or do they hook up to a control box first? What engine package and shifters/controls do you have?
It is original equipment.
Unless the control box is behind the steering wheel cabinet, they go first to the helm controls, then a second line goes straight to the cockpit.
I have Crusader 350 xl engines - I will have to check on the shifters/controls later this week when I get back to the boat.
Thanks!
Drew
- Been thanked: 1111 times
- drewp
km1125 wrote:Source of the post I wonder if there could be some tension on the cable when the shifter is in gear... maybe the two (four?) cables are tied together too tightly at some point?
I will look at that - all the cables are zip tied together, so it may not be readily apparent - thanks!
