Thruster for 4207
Pierre
Topic author - Scurvy Dog
- Vessel Info: 1988 Carver 4207 Aft Cabin T-3208 Cats
Thruster for 4207
I am getting more serious about the project and looking for specific information.
I am currently looking to install a a single prop unit by Vetus with a 10in tunnel and 275lb of thrust.
Do you have any idea if this sounds adequate? Most other installations in my area (Montreal) on large Bayliners or Carvers have a 7in or 10in tunnel with dual props (non-Vetus).
Any comments?
thank you.
SHEMP
- Vessel Info: 2000 CARVER 456 MY
Full Bridge and aft deck enclosure
Originally purchased in Staten Island
Second owner also purchased in Staten Island in 2012
Now berthed in Toronto Canada
A wonderful and fully appointed luxury yacht. - Location: Toronto Ontario Canada
- Been thanked: 4 times
Re: Thruster for 4207
it seems to me that your Vetus Single will be more than adequate. I can't say one way or the other about single vs twin props, because this is my first boat with a Bow Thruster.
I just looked at my manual for the Side Power SP 95T , this is the unit Carver installed at the factory for my 456.
The boat weighs 35000 lbs.
The SP95T is a dual prop and seems to be quite sufficient for my boat which is almost 46 feet long.
Thrust = 209 lbs
Tunnel = 7.28 " or 185 mm
weight of unit =68 lbs
Motor output = 8 hp
I hope that helps .
Victor
Pierre
the Vetus Bow unit 12512D Model has 8 hp, a single prop (6 blade) and 275 lbs of thrust. This is their largest unit that works on 12V and requires a large tunnel (9 7/8 in - 250 mm).
My 4207 has a full enclosure on top and on the aft deck so it has a large wind exposure.
Hopefully, this unit will do the job!
thanks again!.
Pierre
