Carver Santego 380 Walkthrough Panels
- Santego2000
- Vessel Info: 2000 Carver Santego 380
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
Re: Carver Santego 380 Walkthrough Panels
“Escape Plan”
Murray, KY
- Been thanked: 1113 times
However, I think you could make some out of Starboard if you couldn't find the real ones. The only trick would be forming them over some type of a "mold". I made some forms out of scraps of wood then then heated Corian in my oven and dropped them on the forms. Worked perfectly.
Your pieces might be too large to fit in a conventional oven, but you might be able to rig something with some high wattage lights.
- JimN
- Vessel Info: '89 Carver Santego 38
- Been thanked: 3 times
You could make them from Fiberglass, too. www.boatworkstoday.com has at least one video showing him making a hatch cover and it would be done in a similar way, using thin bending plywood and wooden pieces that have been cut to match the curve, glued to the backside of the form. He used particle board with a Melamine surface and it's available in 1/4" thickness, but I think I would go to a big box store and buy a small sheet of laminate, use contact cement to attach it to the curved panel (to prevent the resin from sticking) and by making it longer than you need, you can cut it to fit.
