Removing salon panels
- tgherzog
- Has thanked: 3 times
- Been thanked: 5 times
- Been thanked: 1111 times
Re: Removing salon panels
https://www.amazon.com/christmas-tree-f ... +fasteners
You just pull (or pry) the panels down. Sometimes the fasteners break and need to be replaced. Other times they some loose and can just be pushed back in place.
Good luck and let us know how it goes and what you did.
- tgherzog
Viper wrote:Source of the post I agree with km, a lot of panels I've dealt with were held in place that way. I get what you mean though, it's definitely nerve wracking to pull when you think you might be breaking something. It's a leap of faith but if you can't see any other way they could have fastened the panels, then the plastic retainers are most likely what's been used. Pry a little at a time along the length of each panel so you until the panel comes loose. Depending on its construction, prying only one corner all at once could result in the panel breaking. Use flat pry bars. I have a few good stainless ones that I use for this type of job, they work great. If you're worried about marring the vinyl, cover the bar with a clean ray before inserting the bar.
Finally got back around to this, and y'all were right. The panels employ christmas tree fasteners and pull down easily. They push back in place almost as easily. I got some spare fasteners on Amazon just in case anything broke on the way back in, but I didn't need them. Thanks for your help.
Users browsing this forum: geo and 43 guests
