Dash switches.....
- jhnybgood
- Vessel Info: 1991 CARVER 26 COMMAND BRIDGE
Dash switches.....
- Been thanked: 1113 times
Re: Dash switches.....
- jhnybgood
km1125 wrote:Source of the post I think the cover snaps off there and then it's a pretty standard switch underneath. What are all the numbers printed on the sides of the switch?
No number on switch. Just 12v Mexico Carling.
- jhnybgood
Viper wrote:Source of the post It's just a DPDT Carling switch. You can get the entire assembly or just the switch itself and install your existing rocker on it. Any brand of DPDT switch that will accommodate that rocker design will work. Is every terminal on the switch actually being used; 6 wires?
That I don't know. Just bought the boat. It's the nav light switch so I don't know why they would be. Gonna chase the wires today and see
jhnybgood wrote:Source of the postViper wrote:Source of the post It's just a DPDT Carling switch. You can get the entire assembly or just the switch itself and install your existing rocker on it. Any brand of DPDT switch that will accommodate that rocker design will work. Is every terminal on the switch actually being used; 6 wires?
Nav lights have a tendency of being left on and burning out. I know you want to change the switch but have you checked the nav light sockets for power?
- jhnybgood
Midnightsun wrote:Source of the postjhnybgood wrote:Source of the postViper wrote:Source of the post It's just a DPDT Carling switch. You can get the entire assembly or just the switch itself and install your existing rocker on it. Any brand of DPDT switch that will accommodate that rocker design will work. Is every terminal on the switch actually being used; 6 wires?
The starboard one is good for sure. Port? Need to get it apart. The screw heads are stripped.
- jhnybgood
- Has thanked: 602 times
- Been thanked: 1311 times
jhnybgood wrote:Source of the post Starboard is good for sure. Can't open port because the screw heads are stripped.
You would be surprised what you find inside those things.....sometimes a little cleaning of the socket and grounds then continuity check is all that is needed.
- jhnybgood
