Coolant Leaks
- Terra Nova
- Vessel Info: 2002 Carver 410 Sports Sedan
- Has thanked: 2 times
Coolant Leaks
Any ideas on how the coolant level dropped but no visible leaks?
- Been thanked: 1113 times
Re: Coolant Leaks
I'm curious about happened to the "reservoir plugs"... did they leak or just fall out? Do you have a pic of these?
I wouldn't expect a leaking reservoir to drain all the coolant in the engine, just what's left in the reservoir.
Re: Coolant Leaks
- plittle2005
- Has thanked: 16 times
- Been thanked: 37 times
Re: Coolant Leaks
if you pull the HEX anode out and coolant comes out, the tube bundle has failed, and coolant will disappear. In any event, have the HEX's pressure tested, can be done in the boat
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: Coolant Leaks
- Has thanked: 603 times
- Been thanked: 1311 times
Re: Coolant Leaks
