Polarity lights indicators questions...
- benica
- Vessel Info: 1997 355 Aft cabin. 7.4 engines.
- Has thanked: 1 time
- Been thanked: 9 times
355 Aft Cabin. Electrical panel. Two polarity indicators/lights; red green.
Couple of boat electricians came out...did some buss and wiring repairs. 2 separate companies.
Here's where they don't agree. One says the indicators should flicker green meaning correct connections. Other guy says no...should be solid bright green always and these indicators should be replaced...old and worn out.
Been looking for replacements to no avail. Great Lakes Skipper..none. West Marine none, Boat Owners Wearhouse none..da da da..wanted to buy the same ones...plug and play and no drilling a larger opening.
So.. should the green light flicker or be solid green?
If solid...then apparently a flickering green means...what...issues?? Possible causes? All ground wires replaced. All buss connections replaced. Any corroded wires replaced. No bonding issues apparently according to the electricians.
Appreciate your thoughts and leads where to buy...
- Been thanked: 1113 times
Re: Polarity lights indicators questions...
The boat really should have the mains wired so that they TRIP if it senses that there's a reverse polarity condition. Did either electrician mention that?
** If you'd want to be really enterprising, you could probably repair the light by figuring out how to open it and just replace the neon bulbs inside. I'm sure you can still get neon bulbs somewhere.
https://www.lvelectronics.com/details/item?itemid=SOLICO%203450-4-50-19314#
- benica
