crusader 8.1l 2007 diagnostic plug
mxproulx
Vessel Info: carver 41cmy 207 twis crusader 8.1l mpi
Postby mxproulx » July 3rd, 2023, 3:32 pm
HEY GUYS
i hav a 2007 carver 41cmy with twin crusader 8.1l mpi ..
i got a diacom adaptor with softwate and plug for my mefi7 ecm how ever i cant find the rectangular 6 or pin connector
for connection to my diacom adaptor ...
i talked to a crusader dealer in the us and told me the plug is on engien starbord side master... how ever i doubt the startboard is my master since the round big plug for throttle control has nothign hooked to it....
anybody can shed me some light maybe the diag plug is hidden soemwhere on the boat
Re: crusader 8.1l 2007 diagnostic plug
Postby bud37 » July 3rd, 2023, 5:46 pm
Welcome to the forum.....they are very secretive/inventive when it comes to that port... :-D ....have a real good look around........under the harness near the engine front, under the ecu if mounted on the engine/riser, sometimes taped/tie wrapped to the harness wiring. If it has never been used it will be hidden.......good luck with your search, maybe someone with the same package knows exactly where it is located.
paulr
Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
Has thanked: 56 times
Been thanked: 32 times
Postby paulr » July 4th, 2023, 9:23 pm
I have a 2001 396 with 8.1 Crusaders. The surveyor found but 6 months later I can't find it because i was going to buy the diagnostic instrument and the seller wanted a picture of it. Ill look again after reading the post above.
