Port side bilge water not draining
- Agriman
- Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
- Has thanked: 5 times
- Been thanked: 5 times
- Has thanked: 603 times
- Been thanked: 1311 times
Re: Port side bilge water not draining
- Agriman
Agriman wrote:Source of the post The bilge pump in front of the batteries runs after rain and washing the boat but always has a small amount of water.
If the discharge hose from that pump runs thru the bottom of the stringer to the stbd side you may probably find they did not seal that passage very well and it generally drains the stbd engine bilge space thru to the center where the hose runs thru.....good thing that stringer is some sort of composite......they also screwed the battery shelf right into the bottom of those stringers as well with no sealant......something to look at......
