Fuel Level Sensors
- Cain8768
- Vessel Info: 2000 Carver 396
- Has thanked: 5 times
Fuel Level Sensors
I am adding fox gateways to the engines to get readings directly from the source but I don't believe that will do anything for the fuel level.
Any help or advice in getting this figured out would be appreciated.
Thanks!
- Been thanked: 654 times
Re: Fuel Level Sensors
You can go to their website and see what data is available.
Have you recently started having these problems? Is this a new install? Have they been calibrated? Did you just piggyback onto the existing fuel level sensors? What are the analog fuel guages that came on the boat doing are they reading properly? Probably need a bit more info to really help .
- Hoplite808
- Vessel Info: 1988 Carver 3227 Convertible
- Has thanked: 1 time
- Been thanked: 8 times
https://www.westmarine.com/moeller-reed ... 3_537.html
- RobGunn
- Vessel Info: 1990 Carver 3607 Aft Cabin
"FINALLY" - Location: St. Joe MI
- Been thanked: 23 times
I have a access plug in the top of each tank that I can insert a 1/4" wood dowel rod. This gives me real fuel level. Yes just make sure the plug goes back in snug.
- Been thanked: 1113 times
RobGunn wrote:Source of the post I have never trusted my fuel gauges on the boat. They are near correct but for a "real" reading I go old school.
On a 3607 you should be able to stick the tanks right from the fuel fill. The fill hose goes straight down into the tank.
- Has thanked: 602 times
- Been thanked: 1311 times
Of course this doesn't work for all boat designs.
