Port Engine won’t start
Thelma Jean I
Vessel Info: '95' Carver Santego 380
Has thanked: 21 times
Postby Thelma Jean I » July 6th, 2023, 9:00 pm
Hello everyone! I got a 95 380 Santego with 454XLi engines. It’s cranks but won’t turn over.. any troubleshooting advice?
Thanks!!!
Hoplite808
Vessel Info: 1988 Carver 3227 Convertible
Been thanked: 8 times
Re: Port Engine won’t start
Postby Hoplite808 » July 6th, 2023, 9:34 pm
What do you mean by it cranks but wont turn over? Is the starter motor running but the crank isn't being turned? If so its either a flat spot on the flywheel or a bad starter motor. If the crank is turning and its not starting there are only two possible reasons for an engine not to start. It's either not getting fuel or its not getting fire. You'll have to test for spark at the spark plugs and if there is none then trace the ignition system back till you find the fault. If you have spark then try putting a shot of starting fluid down the intake. If it starts then dies the engine isn't getting fuel. You'll have to trace the fuel system back to find the fault.
Postby Viper » July 6th, 2023, 10:12 pm
I'm assuming she's cranking/turning over but won't run? If that's the case, as mentioned, go back to basics and make sure you're getting spark and fuel. Last time ignition tune-ups were done? Does she have spin-on fuel filters and are they full of fuel? Does it crank over really easy or is she labouring?
Postby km1125 » July 7th, 2023, 7:44 am
Does this affect both engines or just one of them?
Thelma Jean I
Postby Thelma Jean I » July 9th, 2023, 11:35 pm
Viper wrote:Source of the post I'm assuming she's cranking/turning over but won't run? If that's the case, as mentioned, go back to basics and make sure you're getting spark and fuel. Last time ignition tune-ups were done? Does she have spin-on fuel filters and are they full of fuel? Does it crank over really easy or is she labouring?
Yes it wont run.. battery power is there, fuel is working properly (New fuel filters for both sides). Once I have time later in the week, my brother and I will check on the spark plugs an I will certainly give an update. Thanks
Thelma Jean I
km1125 wrote:Source of the post Does this affect both engines or just one of them?
Just the port side.. checking spark plugs later in week.
Thelma Jean I
Postby Thelma Jean I » July 11th, 2023, 5:21 pm
UPDATE!!! All new spark plugs installed. Still not turning over to stay running. Any more suggestions?
Postby km1125 » July 11th, 2023, 5:32 pm
Thelma Jean I wrote:Source of the post
How do you know "fuel is working properly"... have you checked the fuel rail pressure before or while trying to start?
Were the filters pre-filled when you replaced them? How long ago were they replaced, and has the engine run fine since then until now?
Thelma Jean I
Postby Thelma Jean I » July 25th, 2023, 10:42 am
Update: Fuel pressure is proper, fuel filters filled and replaced in March. Engines were running like champs for 2 months afterwards completely fine.
Spark plugs changed, ignition coil and module replaced. Engine still will not start. I've gotten the suggestion that a scan tool may be needed now.
Postby km1125 » July 25th, 2023, 11:49 am
If it's cranking over and not starting, then you're back to basics. Compression, spark, fuel. You can do a lot of that checking without scanning the ending ECU. And a LOT of problems that would prevent the engine from running will not show up in an ECU of that vintage.
Did you check fuses and breakers? If there's fuel pressure in the rails, are the injectors firing? Do the plugs get wet from gas? Have you checked that any of the plugs are actually firing with a good, hot spark?
Users browsing this forum: No registered users and 47 guests
