Cabin odor
- Baroloman
- Vessel Info: 1986 Carver Mariner 32 (3297)
Cabin odor
- Cooler
- Has thanked: 68 times
- Been thanked: 406 times
Re: Cabin odor
- Curly1
- Vessel Info: 2004 Carver 466MY
- Has thanked: 2 times
- Been thanked: 3 times
Re: Cabin odor
- Has thanked: 598 times
- Been thanked: 1281 times
Re: Cabin odor
Baroloman wrote:Source of the post I have read a fair amount about the line from the toilet to the black tank becoming permeated and causing an undesirable odor. I can see also that replacing that line is a solution for said odor. That however, appears to be easier said than done on my '86 Mariner 3297. Has anyone had success with other solutions?
Welcome to the forum.... IMO ,unfortunately there is no fix short of replacing the lines with new......you can hide it but it will always return when boat is closed up in summer, just the way it is and is near impossible to get completely out without some serious attention to detail cleaning.....
One repair you might try though is to replace the pumpout hose from the bottom of the tank up about 3 or 4 feet.....that piece of hose is where the contents sit and stew, a common source of the odor....replace it with the hard white plastic pipe....you can get adaptor fittings to do this.......the pipe does not allow odor thru as the hose does.
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 23 times
Re: Cabin odor
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
Re: Cabin odor
attach firmly (drill holes) a long line/wire/chain to the end and pull the old hose out at the other end (!) so that the wire/chain is in place of the old hose.
Attach said wire/chain to the new hose and manhandle it through.
A warm hose bends easier, also easier to attach to a barb.
Don't forget clamps before your final attachment to the tank/source of nose-evil.
Test run with water only
lots of water, flush the whole system to infinity and beyond.-
Drspikes355
- Vessel Info: 1996 Carver 355 aft cabin Crusader 454’s
- Has thanked: 135 times
Re: Cabin odor
It’s worth looking into it. Unless you’re sure it’s the mentioned hose for sure. You can test for it with a damp rag rubbing over the suspected hose and check for odor on the rag. It’s worked on friends boats. Let us know. Good luck.
Users browsing this forum: Google [Bot] and 23 guests
