"Sluggish" port engine shaft
- Superg
- Vessel Info: 1985 Carver 3207 Aft Cabin
Harbored in Lake St. Clair, MI - Location: Detroit, MI
- Has thanked: 4 times
- Been thanked: 20 times
So now with my boat in water, the same thing. Rotating the port shaft faces VERY noticeable resistance => engine must do more work to turn it. Starboard shaft rotates freely and efficiently.
I was hoping this was just an issue with the cutlass bearing, but I know that was optimistic thinking. I really think the truth is that the resistance is coming from inside the port engine itself. Any thoughts? Hate to have to have this engine pulled out when the boat otherwise seems to run well. But I know that resistance must have an effect that the engine has to overcome.
270 Crusaders.
New Boat Owner (so lots to learn)
Harbored in St Clair Shores, MI
- Has thanked: 602 times
- Been thanked: 1311 times
Re: "Sluggish" port engine shaft
Could be bearing/shaft alignment as well.....what makes you think the bearing is ok ?
- Been thanked: 1113 times
You could have a few things going on. There could be an alignment issue which is causing some binding. You could disconnect the coupling and check that, and while it's apart compare how each shaft turns (which would just have the stuffing box and cutlass as culprits). If the those are ruled out and you address any alignment issues, you could easily have differences within the reduction gears or transmission. You could have some freeplay in one and some bearing load in the other, or you could have some minor warping on some clutch plates. If it's the forward clutch plates that are warped, then that's not an issue at all once you're in gear, as those plates are locked together.
- plittle2005
- Has thanked: 16 times
- Been thanked: 37 times
It is not due to blocking on land.
You have 3 parts in your drive train: trans, stern tube/stuffing box and cutless. Each can be checked separately. You must unbolt the flange at the trans.
If the trans-side flange rotates freely, it is good. This can be checked in the water. But if hard to turn, then a problem is developing within the trans and must be corrected by pulling and rebuilding.
But if the shaft itself is binding, then a short-haul is required to loosen the stuffing box gland and check the cutless and strut alignment.
If loosening the stuffing box reduces rotating resistance, then best to pull the prop and shaft out to check shaft seal surface condition and straightness and to replace the packing.
The cutless will be worn more or less, but if any detectable sidewise slop, it should be replaced. Easy to do at this point. (Good time to do the other cutless as well. This can be done shaft-in if the yard has the special puller. Most do.)
Methodical inspection will find the problem. I think serious problems could result from this condition, so you are right to address them now.
- Superg
Well, I put it in a work order for the marina service department to address over the winter. I asked them to check and probably replace all the shaft bearings first, and if the issue is still there to look farther up the powertrain.
- plittle2005
Checking is simple: remove the 4 flange bolts at the transmission.
1. If the transmission flange turns hard, you've got a trans problem which will require removal and rebuilding. If let go, it would thoroughly trash the trans. Big $$!
2. If the shaft turns hard, you've got a bad stuffing gland seal or some other shaft alignment problem. The gland could fail and sink the boat.
Bottom line, you need to find out now, don't keep running until maybe big disaster!
