Not engaging into gear right away
Lisasammy
Vessel Info: Santego 30
Postby Lisasammy » August 7th, 2023, 7:17 pm
I have a 1990 Carver santego with twin volvo pentas. Shifting into neutral has always been tricky. It's almost like I have to shift past neutral first before it will go into neutral but I just got used to doing that. Now a new problem that just happened, is when going into reverse it didn't engage right away until I gave it more throttle then it made a loud slam into gear. The first time I noticed something wasn't right is when I was pulling in my slip and put the port engine into reverse, in and out quickly just to slow me down, and it didn't go into gear so I quickly through the starboard engine in reverse. Has anyone else had this problem or know what it could be. Any suggestions would be greatly appreciated.
Thank you.
Lisa
Re: Not engaging into gear right away
Postby bud37 » August 7th, 2023, 8:20 pm
Welcome to the forum.......is this an outdrive boat ?
Lisasammy
Postby Lisasammy » August 7th, 2023, 10:10 pm
Hi, it's an I/O
Postby Viper » August 8th, 2023, 7:13 am
More equipment info would help. Is it a Mercruiser, Volvo? What model sterndrive? If it's a Mercruiser, the most common culprit for both Alpha and Bravo drives is the lower shift cable. You can try adjusting but if it started off as a minor issue and getting progressively worse, it's a pretty good bet the cable needs to be replaced. Other possibilities are improper idle rpm, bad interrupt circuit/hardware (Alpha), bad remote/shifter, wrong gear lube, worn internal drive components, etc.
Postby bud37 » August 8th, 2023, 7:59 am
I think Lisa said they were volvo pentas if that helps....I have zero experience with them.
Lisasammy
Postby Lisasammy » August 8th, 2023, 7:55 pm
Yes, they are volvo pentas. I'm wondering if the cables need tightened. Im hoping its nothing too serious. What other information would help?
Postby Viper » August 8th, 2023, 9:27 pm
Do you know the model and serial number of the drive? Volvo will have a single cable from the drive to the remote at the helm. Do you know if it has ever been changed? When was the last time the gear lube was checked/changed?
Lisasammy
Postby Lisasammy » August 9th, 2023, 5:25 pm
Since I've owned it for 3 years the cable has not been changed. Gear lube checked beginning of season. Not at Boat to look up serial number. I don't seem to get as much speed full throttle as I did when first purchased. When it should be in neutral, it's still moving. I have to bump it past neutral then back in again to go into neutral, and now not engaging until giving more throttle.
Postby km1125 » August 9th, 2023, 8:40 pm
Sounds like something is either loose, or a cable is stretched.
Lisasammy
Postby Lisasammy » August 9th, 2023, 8:48 pm
I'll check the cables and see if that helps. Thank you
Users browsing this forum: Google Adsense [Bot] and 37 guests
