1997 355 Aft cabin central vac questions..
- benica
- Vessel Info: 1997 355 Aft cabin. 7.4 engines.
- Has thanked: 1 time
- Been thanked: 9 times
Electrical panel shows a breaker for the central vacuum system. Apparently system was removed or never installed.
Wiring is there though...breaker has the wires attached and routed into the harness with other wires.
My question...where would the canister had been mounted/located?
The ends of the wiring should be capped off somewhere near where the canister would had been....
There are no ports/holes that I can see where the vac hoses would have been connected when using...
Thank you!
Re: 1997 355 Aft cabin central vac questions..
- Been thanked: 654 times
