Can't open sliding windows in Salon - 1987 Santego 3067
- theorifice
- Vessel Info: 1987 Carver Santego 30
- Has thanked: 16 times
- Been thanked: 4 times
I'm happy to go whole hog and scrape whatever is on the track but want to check if there is something else I'm missing. From what I can see, there is a small brush strip and some sort of rubber on the track.
Should the windows be easy to slide open and close and the tracks require cleaning or is there some other mechanism that I need to account f or
Apologies for lack of picture.
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Can't open sliding windows in Salon - 1987 Santego 3067
Hopefully nobody siliconed em shut due to leaks.
- quickdecision
- Vessel Info: Carver 3807, 1987
- Been thanked: 23 times
Ron
- theorifice
Once the bottle jack support is removed, wouldn't the sag return and cause the window to stick again?
- theorifice
- quickdecision
compression issues. If frame is good, Reassemble using butal caulk on out side. do not tighten screws all the way. After one or two weeks tighten screws.
Winter time project, you can also reanodize frame while its out.Check D K Hardware for rubber or felt seals.
Ron
Users browsing this forum: No registered users and 44 guests
