Waste Tank overflowed?
- theorifice
- Vessel Info: 1987 Carver Santego 30
- Has thanked: 16 times
- Been thanked: 4 times
Waste tank is definitely full now and more than likely overflowed. What happens when the waste tank over flows? I had maybe though the head would have overflowed and drained into the shower sump but didn't see any evidence of that today.
I've since fixed the issue by disassembling the valve and removing a piece of rubber.
- pepmyster
8.1 Volvo Penta
- Has thanked: 487 times
- Been thanked: 206 times
Re: Waste Tank overflowed?
- Has thanked: 468 times
- Been thanked: 1765 times
- Been thanked: 1180 times
Curious too though how it overflowed the tank and not the toilet bowl.
Same here.
- theorifice
I'm thinking there might be something more going on. Do you have an overboard discharge system? I wonder if someone plumbed the toilet incorrectly.
- Has thanked: 598 times
- Been thanked: 1281 times
With any other design that utilizes a pump be it manual or electric, as soon as fluid in the bowl gets low enough that the pump starts sucking air, that's it for pumping fluid efficiently, it will pump air easier before it gets whatever water is left at the pump. Even if it gets all the water (downhill to pump) it won't pump it to the tank once it starts sucking air. The hose from the toilet to the tank will always have waste in it and is the number one reason for permeation.
