Door removal
Agriman
Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
Has thanked: 5 times
Been thanked: 5 times
Door removal
Postby Agriman » September 15th, 2023, 10:06 am
[code]Anyone have any advice/ idea for the sliding door removal on a 350 Carver Mariner? I need to replace the insulation at the top in the track.
Has thanked: 603 times
Re: Door removal
Postby bud37 » September 15th, 2023, 11:22 am
Seems to me there may have been a thread about this door removal/adjustment a few years back....
Australia
jonny12
Vessel Info: my vessel is 2003 Carver Yacht 366
Has thanked: 3 times
Re: Door removal
Postby jonny12 » September 23rd, 2023, 8:03 am
i am not a pro but i wanna provide you some general tips:
Safety First: Ensure the boat is securely docked or anchored, and the area is well-lit to prevent accidents.
Clear the Area: Remove any obstacles or items that might obstruct your access to the sliding door.
Remove the Door Handle: Most sliding doors have a handle that can be unscrewed or detached. Remove the handle first.
Check for Screws and Fasteners: Look around the frame of the sliding door for screws or fasteners.
Lift the Door: With the fasteners removed, gently lift the sliding door up and out of the track.
Inspect and Replace Insulation: Once the door is removed, you can access the top track and replace the insulation as needed.
Australia
jonny12
Re: Door removal
Postby jonny12 » September 23rd, 2023, 8:27 am
Sliding door removal and insulation replacement can be a bit tricky, but doable. Do you know the type of insulation material you'll be using for the replacement?
Pura Vida
Vessel Info: 93 Carver Mariner 330. 2X 350XL Crusaders
Has thanked: 17 times
Been thanked: 10 times
Re: Door removal
Postby Pura Vida » September 23rd, 2023, 9:28 am
