Walter RV 40 V drive fluid change
- ron54
- Vessel Info: 2006 Crownline 262ex
1985 Carver Mariner 3697 - Location: Table Rock Lake Missouri
- Has thanked: 12 times
- Been thanked: 4 times
Have the Velvet drive trannies done, now to the V drives which are independently mounted and easily accessible through hatches in the salon. Have found several manuals for procedure, only real question is fluid type. I have read 30 weight HD motor oil which I can only find in detergent type. Others say non detergent 30w which is available at Wally World and part stores. I called Walter and they said 30w motor oil, either detergent or non is fine. Another manual states to add 2 oz. Molybdenum disulfide (molykote) for break in, not needed after that but good to add. To confuse things further my original Crusader manual lists EP68 or APG-80 gear lube, both difficult to find.
Probably overthinking this, will go with what Walter company said, but any thoughts welcome. Also thoughts on the Molykote.
- Has thanked: 598 times
- Been thanked: 1281 times
Re: Walter RV 40 V drive fluid change
Yup do what Walter says.
Sometimes you can find gear oils like that at tractor supply places in bulk, equipment dealers etc.
- ron54
- ron54
Here is response
“ No need for molykote, it can hurt more than help.
You can use SAE 30 heavy duty motor oil, either detergent or non detergent.”
Interesting that they longer recommend molykote.
- Has thanked: 78 times
- Been thanked: 1093 times
I could see them not recommending it, as it could be "overkill" and unnecessary with the increased shear strength on modern heavy-duty oils.
By this, I mean drain and fill, run, then drain again and fill again a few times.......that way you will be sure of what you have in there. This only applies if you have no idea what is in there now and will ensure consistency.
- ron54
That begs a question about engine and genset oil, I probably should post a new thread for future reference.
