3607 Aft Cabin - draining water in engine compartment underneath the engines
JeffandErin
Vessel Info: 1984 Carver 3607 Aft Cabin
Been thanked: 2 times
Postby JeffandErin » September 24th, 2023, 8:11 pm
I have been doing some work on the intake strainer for the AC systems. It sits horizontally instead of vertically like all other strainers. So, taking the cap off to clean the strainer drains a lot of water from the pump and lines. Additionally, just putting the cover back on creates an air lock when you open the seacock valve again. This necessitates "burping" the air out of the system by cracking open the filter cover and letting both air and water drain out until all the air is expelled.
So this post is not about burping the AC seacock filter, its about getting rid of the water that has now collected under the starboard engine (Crusader 350s though that makes no difference).
There are the two central stringers that run fore to aft with the batteries situated between them. The aft bilge pump is located in this space, just forward of the aft bulkhead.
However, the water is not collecting in this space. It is collecting under the starboard engine, to the outside of the starboard stringer.
How is this water supposed to be drained out?
Been thanked: 1111 times
Re: 3607 Aft Cabin - draining water in engine compartment underneath the engines
Postby km1125 » September 25th, 2023, 9:39 am
I had the same boat, and same issue. When you get up on plane the water runs to the back of the engine compartment and will run thought the limber holes into the lowest part of the bilge. If your shafts drip excessively you get the same problem. You can end up with several inches of water in that section below the engine(s).
You also have the same issue with the outboard stringers located under the fuel tank, but water isn't as likely to collect there. I had a pinhole leak in one of the potable lines over there that caused a bunch of water to build up.
On the stringer you're talking about, I actually ended up drilling some additional limber holes about 8" from that forward bulkhead. Then both sides drained into that part of the compartment where the bilge pump is located. I also added a second smaller (500GPH) automatic pump in that area to take care of these kinds of "nuisance" water collections. In effect, it turned the main bilge pump there into an "emergency only" bilge pump. It would still be activated by the normal float switch or the manual helm switches.
JeffandErin
Postby JeffandErin » September 25th, 2023, 9:59 am
KM1125 - Thank you very much for your reply and insite. As I created the issue by burping the AC filter, Im not overly concerned about putting another bilge outboard of the stringers. Guess I will simply take my shopvac out and vacuum up the water. Thanks again for your response and your wisdom
Pupicman
Vessel Info: 1999 carver 505
Postby Pupicman » November 15th, 2023, 10:54 am
I have a Carver 1999 504, and it appears there is no way for water in engine bays to flow to bilge pumps. Had an emergency once where prop shafts leaking and filling up engine bays. Had to manually pump out. Any good news/advice out there? Thanks! Bill
