1984 Crusader 350 - Spark Plug Recommendations
JeffandErin
Vessel Info: 1984 Carver 3607 Aft Cabin
Been thanked: 2 times
Postby JeffandErin » October 8th, 2023, 5:56 pm
New to me 1984 3607 AC. Did my annual maintenance and replaced the spark plugs. Based upon recommendations I put in Champion RV12YC plugs
What I pulled out were Champion RV8C plugs - put in by PO
The RV8Cs were pretty black (of course, I have no idea how long there installed.
So, what are your recommendations?
Re: 1984 Crusader 350 - Spark Plug Recommendations
Postby km1125 » October 8th, 2023, 11:39 pm
I think I ran the RV12YC in mine most of the time. The last few years I used the ACDelco R43TS or R44TS (can't remember which).
Been thanked: 413 times
Postby Cooler » October 9th, 2023, 5:54 am
I have used MR43T's for years. Always happy with those. The manual for my 350XL's specs out MR43T, MR44T, or RV8C. The gap is disclosed as .045. Most stock plugs come gapped at .035, so need some adjustment there. 8-) er
Postby bud37 » October 9th, 2023, 9:33 am
JeffandErin wrote:Source of the post The RV8Cs were pretty black (of course, I have no idea how long there installed.
I wouldn't base any decisions as to heat range based on those plugs being black if that is what you are inferring. You really can't take a definitive plug reading on an older carbed engine that has been just idling around.
Cooler wrote:Source of the post Most stock plugs come gapped at .035, so need some adjustment there
Cooler your engines are much newer with a different ignition system I think, unless the ops have been upgraded.
These kind of spark plugs are fairly cheap, so very good to change regularly. Good job keeping up with the maintenance.
