1993 carver 350 aft cabin propeller size
ataylor233
Has thanked: 83 times
Been thanked: 7 times
Postby ataylor233 » October 22nd, 2023, 11:31 am
I have a 1993 carver 350 aft cabin ... powered by twin 454xl's does anyone know the prop specs ??
mine has a few numbers on it 279Z,299F,E636 not sure what they mean google didn't seem to know anything lol...
Been thanked: 285 times
Re: 1993 carver 350 aft cabin propeller size
Postby buster53 » October 22nd, 2023, 12:12 pm
Why do you feel like you need a change? Correct me if I’m wrong, but those engines are made to top out around 4500 RPM’s. What is your WOT? If you are close to that number, assuming your engines are running right and the bottom is nice and clean, then you probably have the correct props.
Postby km1125 » October 22nd, 2023, 12:17 pm
If you look around more on the props I'm sure you'll find them stamped somewhere. I can't think of the last time I saw ones that weren't.
ataylor233
Postby ataylor233 » October 22nd, 2023, 12:18 pm
km1125 wrote:Source of the post If you look around more on the props I'm sure you'll find them stamped somewhere. I can't think of the last time I saw ones that weren't.
yeah ive looked and looked i believe they may have been re finished or something .. thank you
Has thanked: 603 times
Postby bud37 » October 22nd, 2023, 1:13 pm
Do you have them off the boat now ?
Contact Michigan wheel or your local prop shop and run those numbers by them.......be sure to check the hub ends..... a piece of fine sand paper may help to reveal things.
Even refinished they generally restamp with the current specs.
plittle2005
Has thanked: 16 times
Been thanked: 37 times
Postby plittle2005 » October 23rd, 2023, 1:37 am
My '92 3307 33' Aft Cabin has 22x22 4-blades, 454's, good performance at 1400 rpm (8 mph cruising) or 3400 rpm (23 mph planing).
Users browsing this forum: No registered users and 71 guests
