Buying Boat with Wet Swim Platform
- tonyp444
- Has thanked: 53 times
- Been thanked: 10 times
The surveyor also did percussion testing on the swim platform and it came back normal, and it still feels solid underfoot, so it seems as though there isn’t a major rot issue (yet).
I’m looking for advice - do you think this is caught early enough that if I drill out the screw holes and fill with epoxy to stop the source of the water, it won’t develop into a bigger issue? Or since it’s already wet, are we past the point of no return and looking at a very big and expensive repair in the future?
Would you be comfortable buying a boat that has this issue, or is it enough of a problem to walk away?
Thanks so much for any guidance you can provide.
Tony
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Buying Boat with Wet Swim Platform
- tonyp444
- Has thanked: 602 times
- Been thanked: 1310 times
- tonyp444
I’m worried that if nothing is done, it definitely will become soft underfoot and then it’s going to be my problem.
- tonyp444
tonyp444 wrote:Source of the post Thanks! Here is what the surveyor said: “Monitor the area closely; if it becomes soft underfoot or percussion testing is no longer normal, have a qualified marine technician inspect and recommend an appropriate repair.”
It will , all depends on how it is handled now IMO.......nobody can really say how long before total failure but the whole width , I can't say either. Bring it up in the negotiation with an estimate of repair, perhaps your guy can help with that.
- tonyp444
I know multiple members on here have tackled this repair themselves but that’s not something I particularly want to bite off for my first project!
- Cooler
- Been thanked: 1111 times
Cooler wrote:Source of the post Another possible explanation. It would make sense that Carver installed some squares of marine plywood around the box base area under the box. If that is accurate, then the meter could be reading the resin in the plywood as water. Did the surveyor perform that same meter inspection on the stringers? What were those readings?er
^^^ Definitely have to consider this. I had a friend who thought (or had been told) that had a "moisture" problem in the deck near his anchor winch. When they tore into it, they found there was plywood there, put in for the strength. There was no actual moisture problem.
There are probably threads on here where folks have opened up their platform to resolve issues and you might peruse those of similar models and years to yours to see what kind of structure they ran into when they had it opened up. Some include good pictures of what they have under the surface.
