Electrical Diagram
bitterb
Vessel Info: 2002 346 Aft Cabin
Has thanked: 5 times
Electrical Diagram
Postby bitterb » December 26th, 2023, 8:01 pm
Hello, I am a new owner to a 2002, 346 Aft Cabin and am having HVAC problems. Does anyone know where to find a service or repair manual? I have the part manual that I found online.
Thanks!
Re: Electrical Diagram
Postby Viper » December 26th, 2023, 8:12 pm
Welcome aboard. You might be able to find one on-line by trying the manufacturer's website. Someone here might have what you need but you need to post the make and model.
Postby km1125 » December 26th, 2023, 9:25 pm
At the very least, post the picture of the control unit for the HVAC. That would narrow down what you have, but ultimately you'll need the actual model number found on the unit.
Been thanked: 285 times
Postby buster53 » December 26th, 2023, 9:37 pm
What problems are you having? It could be something simple someone here has run into and has the solution to it.
bitterb
Postby bitterb » December 27th, 2023, 8:54 pm
km1125 wrote:Source of the post At the very least, post the picture of the control unit for the HVAC. That would narrow down what you have, but ultimately you'll need the actual model number found on the unit.
It's a Marine Air Systems Vector Compact Model VCP 16K. The problem is it will not heat the other 2 units. The water is not too cold.
If you leave it on it starts to cool.
Also, the 2 electric heads are not making any sound. Are there any fuses on these. both quit at once after being in the repair yard for 6 months.
Postby g36 » December 27th, 2023, 9:46 pm
Here's a link for the vector manual..but assuming you have the passport thermostat control. could be set to cool only i will upload that if you dont have the manual...https://www.tropicalmarineairconditioni ... 040415.pdf
Postby g36 » December 27th, 2023, 9:49 pm
Here's the passport manual, check in the programming section. Operating mode to see if it's set to heat and cool not cool only........https://www.marlow-hunter.com/wp-conten ... ntrols.pdf
Users browsing this forum: No registered users and 44 guests
