Fuel (Gas) Send Unit aka fuel level float
- kgarguilo
- Has thanked: 197 times
- Been thanked: 55 times
I am trying to identify what kind of Fuel send units are on my 1999 Carver 406. Meaning manufacturer and specs. The only number I see on the 5 hole mounted send unit is 3349-17 A9.
Ultimately The tank level ports on the Cerbo GX can each be configured to work US tank senders (240 - 30 Ohm) standards; or to configure a custom Ohm resistance range between 0 Ohm and 300 Ohm (requires firmware v2.80 or higher). The tank level inputs are resistive and should be connected to a resistive tank sender. The built-in tank sensor connections do not support mA or 0-5V type sensors, this type will require additional accessories or replacement with a resistive type sensor.
In short, I need to know if my Fuel Sender is Resistance or mA / 0-5v It would be ideal if the specific range of resistance was known. Or, any idea of the manufacturer? Google is leading me down too many rabbit holes without specific knowledge. As always, any help would be greatly appreciated.
1999 Carver 406
- Has thanked: 602 times
- Been thanked: 1311 times
Re: Fuel (Gas) Send Unit aka fuel level float
I have connected Garmin to tank sensors before, just not on a Carver......just connected to the tank terminals at the connection panel and if I remember right all I had to do was tell amts etc after the tank was filled....it has been a few years since that so a bit cloudy. That boat I had installed a complete Garmin backbone thru out though.
Sorry if this is not helpful but all I can remember about it.
- kgarguilo
postby bud37
What does it say on the red sticker.
Oh, crud, I thought that was a warning label and it did not appear to give that info. See close up. 240-30 Ohms. It looks like I can hook it up with some tinned wire after all. Thanks for pointing out to me. I really missed that one.
1999 Carver 406
- Been thanked: 654 times
- kgarguilo
- Engine Room
Aft cabin under bed
V Berth cabin under bed
Since the installation went so easily, I figured let me look at the fuel tanks, apparently they are also easy since bud37 pointed out the info I needed was on the red tag. So today, I will be hooking up one fuel tank to test and see if it works (using tinned wire 18 AWG) If it does connect and seem to work I will do the following tanks:
- Port Fuel (Gas) 97 gallons
Starboard Fuel (Gas) 97 gallons
Aft Fuel (Gas) 145 gallons
Fresh Water 70 gallons
1999 Carver 406
Yep I have ways to remote monitor things on my boat too. Interesting to see what others do too. Once all set up please post
