Oil send unit - Physical location on a 1999 Mercury 454
- kgarguilo
- Has thanked: 197 times
- Been thanked: 55 times
I will go again tomorrow and search for the units as I am adding an additional oil send unit for my Fox Marine Mefi 3 engine gateways. In looking through the service manual Mercury 90-861326-01. I do not see a pictural view that shows the location either. I will try going page by page tonight but thought maybe someone on here may know exactly where it is at.
Once done I will write it up as a project to share. I already have the Engines connected and templates programed on my Garmin 8612 vsx. Looking forward to wrapping this project up. Thanks in advance.
1999 Carver 406
- Has thanked: 602 times
- Been thanked: 1311 times
Re: Oil send unit - Physical location on a 1999 Mercury 454
You are asking about the sender and not the low pressure switch ?
- kgarguilo
bud37 wrote:Source of the post Have a look, back of block top, near the distributor. May have to move some harness to see.
KG Thanks Bud, I will look in the morning and let you know. Yes, the pressure sender to the guage. Fox Marine supplies a TEE so there oil pressure switch can be added to read on the mefi 3 gateway.
1999 Carver 406
- kgarguilo
[image][/image]
1999 Carver 406
- kgarguilo
bud37 wrote:I think you found the switch......look for something that looks something like this.....I am not sure then where exactly that sender is , sorry
For future reference, here is where the oil pressure switch is located. A shout out to Alan at Fox Marine and some videos and pics online that helped to find it. The guidance I received from Alan was, it should be on the port side of the engine and almost at the back and then I found this picture. Note, it was hard to see as when they sprayed the engine black at the factory I guess, they also sprayed the oil pressure switch making it hard to see as it was covered by wire harnesses.
FYI I am doing a video on the install and will supply a link once it is completed.
1999 Carver 406
