Flying Bridge Throttles
Topic author
swodog6289
Vessel Info: "Open Arms"
36ft Carver 3607 Aft Cabin
Postby swodog6289 » June 13th, 2014, 9:19 am
Got a 1986 3607 and the throttle controls are tough and not very smooth to operate.
Anyone rebuilt the throttle controls before?
Has thanked: 64 times
Been thanked: 481 times
Re: Flying Bridge Throttles
Postby waybomb » June 13th, 2014, 8:56 pm
It's probably the cables.
I read somebody's solution to replacing them.
Disconnect the cable and cable end. Slip a 2 foot long hose that just fits over the outer sleeve. Clamp the hose to the sleeve with a hose clamp. Fill the hose with ATF fluid. Plug the open end of the hose with a hose barb. Connect an air regulator to the hose barb. Apply 2-3 psi air pressure. Watch the other end of the cable for the oil to start seeping out.Disconnect the air.
Does it work? I have no idea but it's probably worth a shot!
Topic author
swodog6289
Postby swodog6289 » June 16th, 2014, 7:57 am
I'll be at the boat this weekend and try it.
PCOMT
Vessel Info: "BRAKSPEAR"
1981 3007 Aft Cabin
Has thanked: 4 times
Postby PCOMT » June 30th, 2014, 8:56 am
Did it work?
This could be very useful for others...
Peter
Retired, but not tired, Looking forward to getting out there!
Seif911
Been thanked: 4 times
Postby Seif911 » June 30th, 2014, 9:41 am
Wow...that is some great thinking! I like it. That one will stay in the back of my head.
Thanks,
Steve
Users browsing this forum: No registered users and 7 guests
