12V Neutral wiring
- pwillis@mail.com
- Has thanked: 1 time
- Been thanked: 6 times
12V Neutral wiring
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: 12V Neutral wiring
- Has thanked: 602 times
- Been thanked: 1311 times
pwillis@mail.com wrote:Source of the post I recently purchased a new electric toilet and I had to upgrade the circuit breaker and wiring for the installation. I have a 1999 406 aft cabin. Is there a "neutral bar" or gang connection for neutral wiring in the bow area of the boat? How about the stern? Thank you!!
Do you mean 12 volt dc, if so there is no neutral per se only a negative , ground side. I think this is what you are talking about , but still to be sure.
- pwillis@mail.com
- Been thanked: 1113 times
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
That was not very kind
to say but: 1) find any other aplliance and follow the leads. But you mention that you had to change the fuses and the wiring, did you only put in a new positive lead then? Why not both at the same time?
2) check and confirm that the points you find are capable of handling the currents that your toilet pulls when in operation.
You don't want to connect to anywhere and hope that furtheron from there to the battery a thinner line was used because the expected load was for a lightbulb, not an electric toilet that can get stuck and the positive doesn't blow the fuse in time before the thin lead starts to melt and burn.
With such potential currents, I'd use new wiring all the way to the fuse box and there connect to the bar and a properly sized fuse.
(also because trouble over time often starts at negative bus bars hidden somewhere and you do not want to have trouble with a toilet. That trouble usually surfaces when the toilet was just used.........
) guess how I know.....- pwillis@mail.com
Thanks to everyone for your suggestions and advice!!!- bud37
pwillis@mail.com wrote:Source of the post On the negative side I used the 10 gauge wire that was used for the old vacuflush system because I couldn't find the negative bus bar
I think that is the right way. ...
Also I believe that you may have answered your own question about bus bars, as the original was originally wired all the way back to the panel.
- Wsullivan71
- Vessel Info: 2001 Carver 404 Motor Yacht
- Been thanked: 12 times
"Your boat's 12 volt DC electrical system, AC electrical system, and the batteries' negative leads are all connected to the bonding system through buss bars. The buss bars are located in the engine and aft bilge compartments and are connected to the transom-mounted zinc plate."
