Help with Engine Serial numbers
- AC3207
- Vessel Info: 1986 3207 Aft Cabin
SERIAL NUMBERS:
Port: A483163
Starboard: A492900
- Has thanked: 602 times
- Been thanked: 1311 times
Re: Help with Engine Serial numbers
Can you take a pic of the engine id plates, maybe they are rebuilds....what color are the engines ?
https://cdn.shopify.com/s/files/1/2712/ ... 1657244116
Here is some more info......https://marinepartssource.com/blog/iden ... ne-engines
- AC3207
Posted on another hosting site so maybe they will come through.
- AC3207
PS, I can't see the image you posted.
Viper wrote:Source of the post PS, I can't see the image you posted.
On the pics he posted it shows black engines with Mercury marine tags....not mercruiser, if that helps ?
If you are looking for filters, look at the part numbers of the filters installed, same with spark plugs.
For the raw water impellers, get a good pic of the pump housing. They are most likely standard merc impellers but may have had pumps changed over the years.
Go to the link below, click on the "Main Tree" tab on the left, click on the "Inboard and TowSports" section, click on the "Gas" section, and look for the two models I mentioned above. There will be a few in each category so check the model year. Here you will see a parts breakdown and their part numbers. I tried entering your serial numbers a few different ways but it wouldn't return any results. Let us know if you have a problem navigating through it.....
https://public-mercurymarine.sysonline.com/Default.aspx?sysname=NorthAmerica&company=Guest&NA_KEY=NA_KEY_VALUE&langIF=eng&langDB=eng
BTW, your impeller is 47-59362. Very common and easy to find.
Spin-on Fuel filter - 35-802893T (Merc brand) or 35-802893Q (Quicksilver brand) both are Mercury brands, same filter
- AC3207
