Question re sump
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
Question re sump
When I was filling the fresh water tank on my 2005 Mariner I noticed water coming out of one of the thru hulls on the starboard side of the boat. I checked the boat diagram and it labeled the thru hull as 'SUMP'.
Can anyone explain what the might be? I could not hear the sound of any pump working.
Thanks,
Dennis
- Been thanked: 654 times
Re: Question re sump
- denpooch
I appreciate your thoughts.
Another possibility is a shower sump was just on the edge of going off and was coincidentally triggered.
- denpooch
It was a substantial flow. Even when I shut off the water filling the tank there was still flow.
The shower sump was near empty. The previous day I had run the shower water to confirm the sump was functioning properly.
On reflection, the only thing that comes to mind is that there is an over flow for the fresh water fill connected somewhere to the sump. However I must first confirm that indeed the thru hull in question is in fact connected to the shower sump.
I have had experienced a 'mislabeling' by Carver in another instance.
I will run the shower and confirm that indeed the flow is from the shower sump. I think that must be the first step.
I will post the result of my 'look-see'.
Thanks.
This sounds very probable.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- denpooch
First of all, the diagram provided by Carver is totally mislabeled. ( I would post the image but cannot figure out how to do that!). On the starboard side there is a group of 4 thru hulls.Three of four are labeled incorrectly. I tested the sump, followed the lines, etc and determined that the overflow was coming from the Fresh Water Tank Vent Thru Hull.
So that's that. I got my answer.
Thanks for your help with this.
