2002 Carver 410 Sport Sedan engine power isdue
Geeman
Vessel Info: 2003 410 Sport Sedan
Postby Geeman » May 18th, 2024, 8:02 pm
We purchased our boat in Dec of 2023. Back in April we had been boasting for about 3hrs with a mixture of cruising and idling. When we went to get up on plain we couldn’t get past 10 knots. We ended up getting into a harbour for the night. We checked fuel, transmission and engine fluids. All good. Had a diver check underwater and all good. Next day went to head home and the boat got up on plain with no issues for the next 3 days.
Fast forward to yesterday and we were boating from Victoria to Seattle and were 2hrs into the cruise when the starboard engine powered down. When ended up doing 10 knots to Seattle. The starboard engine would not idle below 1400 or go above 1800. It appears that the throttle is adjusting properly as I played with it on the engine but could not improve on the RPM.
Fuel filters are new in Oct 2023 and have less then 20hrs on them. The mechanic that has worked on the boat the last 10yrs is stumped on what the cause could be.
To add to this. When we ran both engines to get the boat at 10knots. The swim platform was 2” under water. When we ran only the port engine with the boat at 10 knots. The swim platform was 2-4” above the water line.
The boat has the Twin Cummins 5.9-BTA Diamond Series 330 HP diesels
I tried to get a mechanic to look at the boat today with no success. I have some mechanical skills when I have direction on what I should be looking for. I am thinking it may be a linkage issue between the bridge and engine. Does not seem like a fuel supply issue but could be wrong on that. I did check the shut offs in the engine room incase one had shaken closed a bit.
Any thoughts or advice are much appreciated. Thanks in advice.
Been thanked: 413 times
Re: 2002 Carver 410 Sport Sedan engine power isdue
Postby Cooler » May 19th, 2024, 10:34 am
Just a guess, but I would start with the fuel filters. Just cause they don't have a lot of hours on them, doesn't mean their not plugged up in some way. Also check for secondary filters along the fuel line. Seems like I have seen some posts regarding the inline saucer type filters, down the line from main filters, that get plugged frequently. When Viper sees this post, he will chime in. Good luck! 8-) er
Been thanked: 1310 times
Postby bud37 » May 20th, 2024, 9:19 am
Geeman wrote:Source of the post To add to this. When we ran both engines to get the boat at 10knots. The swim platform was 2” under water. When we ran only the port engine with the boat at 10 knots. The swim platform was 2-4” above the water line.
This effect would be normal I believe, when the boat tries to get on plane the aft end will squat ( dig a hole ) as the hull tries to climb the bow wave. with only one engine the hull will be riding on the water for the most part as there is not enough propulsion on one engine to push the aft down thereby creating the swim platform visual.
Users browsing this forum: Google [Bot] and 10 guests
