1990 Carver 3467/380 Steering Cylinder
mikeo1
Postby mikeo1 » May 24th, 2024, 9:02 pm
Hi Folks-
I need information on the]steering cylinder (hydraulic ram) on the above Carver 3467/380 or similar WRT it's make, model and cubic volume (ci or cc) size
Picture of label info I guess would be just perfect
Thanks for your help-much appreciated
Mike
Been thanked: 406 times
Re: 1990 Carver 3467/380 Steering Cylinder
Postby Cooler » May 25th, 2024, 10:44 am
Mike, your probably going to need to get in there and inspect for yourself. Carver used a couple different sizes and types, so there is no way to be sure that one is what you will get as responses, and you don't know if a previous owner switched out. A good marine mechanic can probably recognize the arm quickly. Good luck! 8-) er
Postby Cooler » May 25th, 2024, 11:24 am
Having said that, I looked up the specs for my '95. It is Hynautic K-18 (7" stroke) or a K-19 (9" stroke). If you are experiencing a leak, they can be rebuilt. Any decent hydraulic shop can rebuild. Rebuild cost to me 4 years ago was around $200. Good luck again!
Users browsing this forum: Google Adsense [Bot] and 17 guests
