1988 3227 generator issue
Buggin321
Vessel Info: 1988 3227
Postby Buggin321 » May 30th, 2024, 12:37 pm
Hello all I am helping a good buddy get everything figured out on this new to him vessel. The boat has a 4cyl gas kohler generator. It apparantly hasent ran in 2 years. The boat runs great. I was messing with generator the other day and if I keep pumping the prime lever on the bottom of the mechanical fuel pump every 30 seconds or so the generator runs and sounds great... if you stop the engine dies on the generator. Another pump or 2 to prime and it fires right back up. I have primed it for almost 10 min or so and when you stop priming it shuts off. Bad fuel pump? Clogged vent? I am extatic at how well the gen motor sounds when it is running after sitting so long.
Thank you all.
Has thanked: 603 times
Re: 1988 3227 generator issue
Postby bud37 » May 30th, 2024, 2:10 pm
Welcome.... Is that a flat head four ?
I understand the primer will get fuel but......check and make sure you have proper unrestricted fuel flow to the carb bowl......look back up the line for valves etc. Check the tank pickup if you don't see fuel flow. Could be the pump/ if there is one, but I can say from experience that sometimes those lines can have bad fittings letting air in etc. that creates all sorts of issues. Just check all that stuff first before deciding what else top do.....good luck man.
Buggin321
Postby Buggin321 » May 30th, 2024, 3:04 pm
Flat head 4 yes correct. I think I read about fuel tank vent can cause problems also...
Postby km1125 » May 30th, 2024, 3:46 pm
Fuel tank vent would normally cause problems after something has been running a while. The easier way to eliminate that as an issue is to just leave the fuel fill cap loose or off.
You might want to check the anti-siphon valve at the tank. It's hard for a fuel pump to overcome a sticking one, but a primer bulb/lever might.
Buggin321
Postby Buggin321 » May 30th, 2024, 5:05 pm
Is that at the other end of the fuel hose opposite from the gen fuel selector valve?
Postby bud37 » May 30th, 2024, 8:49 pm
One thing to be aware of......the older Kohlers had an exhaust recall in certain models L600 and L654 from about 1950 to 1989 where they were replacing the cast iron wet exhaust because of CO problems. If you get this thing running I advise you, check the model against the recall and see if the exhaust has been upgraded. Up to a while back they were still providing the parts, can't say what is going on now, perhaps it is already done.
Postby km1125 » May 30th, 2024, 11:26 pm
Buggin321 wrote:Source of the post Is that at the other end of the fuel hose opposite from the gen fuel selector valve?
If you're talking about the anti-siphon valve, it would be located at the fuel tank where the hose attaches to the pickup tube.
Been thanked: 285 times
Postby buster53 » June 1st, 2024, 10:05 pm
I had problems with my Kohler a couple years ago. Replaced the anti-siphon valve and all is good.
