Acrylic sliding door maintenance on Carver 355
- Bentone23
- Vessel Info: 1996 Carver 355 Aft Cabin
454 xli TBI Crusaders - Location: San Francisco Bay
- Has thanked: 57 times
- Been thanked: 5 times
- Contact:
I took the bottom track apart and cleaned it. I’m going to lube with a plastic silicone lube. Then I will put it back.
It was relatively easy to remove the bottom track. I removed the 3 Phillips screws from the bottom of the door. This released the sliding part of the track from the door. I then removed the 4 screws holding the track to the boat. I had to slide the door to get to all 4 screws. Then I pried gently to release the gasket from the track.
It was filthy. I vacuumed the slot the door rides in, then took the track to the sink and washed it with soap and water.
Now off to the store to find some lube.
Bentone23@sbcglobal.net
1996 355 Aft Cabin
Central California
Boating on the Delta and SF Bay
- mjk1040
- Been thanked: 248 times
Re: Acrylic sliding door maintenance on Carver 355
