Bilge odors
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 29 times
Bilge odors
Suggestions?
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Bilge odors
Re: Bilge odors
If the source is bilge water, determine where it’s coming from and correct it. If the water is coming in from non-dripless shaft logs for example which you can’t do much about, then consider a dry bilge system that’s designed to remove pretty much all standing water if done right, otherwise it’s a matter of elbow grease or vacuuming more often.
If the waste hoses are suspect (common), confirm by placing a hot wet rag on a section of low lying hose and leave it there for about 30 minutes. Remove the rag and put your nose to work. If the rag smells, your hoses are permeated and is likely what you keep smelling. The best remedy is to replace the hoses though some have used product like Noflex Digester as a first measure in hopes it will prolong the need for hose replacement.
Of coarse this is assuming you’ve checked other obvious things like a waste leak both liquid and atmospheric. If you have an overboard waste discharge system, check those components as well. Pretty common for the discharge pump/macerator to smell after a while. Same goes for the vacuum pump and associated hardware if you have a Vacuflush toilet.
