96 Carver 455 aft and 10c23 generator
NateFreeman
Vessel Info: 1996 Carver 455 aft 10c Generator 10c23
Postby NateFreeman » June 22nd, 2024, 11:58 am
Super frustrated with generator, it will crank for 4 to 5 seconds and shut down. I changed fuel pump twice and same issue. I have changed plugs, wires seem fine. I took carb off to clean and still same problem. Is it the fuel filter and I will include Pic of what I think may be fuel filter or is this something else? Appreciate any advice sincerely
Nate Freeman
Frisco Tx
Been thanked: 285 times
Re: 96 Carver 455 aft and 10c23 generator
Postby buster53 » June 22nd, 2024, 10:53 pm
Do you mean it only turns over for 4-5 seconds but doesn’t start or it starts and runs for 4-5 seconds and then shuts down
