Ran Aground - Urgent Parts Required 444
chasing28
Vessel Info: Carver 444
Postby chasing28 » June 24th, 2024, 4:28 pm
Ok, I am in desperate need for parts asap and looking for a source for:
2 ea 1001359 11'3" shaft
2 ea 1059021 Shaft Coupling tapered
2 ea 1059066 Coupling
2 ea LP Propeller 24L29 Nibral 2 in bore
2 ea V Struts
2 ea Rudders
Any assistance on sourcing the above would be greatly appreciated.
thank you
Been thanked: 490 times
Re: Ran Aground - Urgent Parts Required 444
Postby waybomb » June 24th, 2024, 5:52 pm
Try Great Lakes Skipper?
Postby Viper » June 24th, 2024, 8:20 pm
It would help if we knew where you were from, you should add that info to your profile so we can see it every time you post. No prop shop close to you? A good shop would be able to source everything.
chasing28
Postby chasing28 » June 25th, 2024, 5:39 am
We are in Newfoundland Vipers. Thanks
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 138 times
Postby KyleR » June 25th, 2024, 9:53 pm
I've gotten parts from General Propeller out of Florida. Very professional and quick shipping. Might be a little pricy but if time is of the essence they pretty much have it all.
Kyle
MV Verity
2002 Carver 396
Brazil
Hugo
Been thanked: 23 times
Postby Hugo » July 21st, 2024, 10:59 pm
I’m a bit late to this but the running gear was made by St Croix machining in WI. 215-386-5144. Croix gear.com The propellers are Acme propellers and 24x29 will leave you over propped/overloaded on that boat. I run 24x27.
Users browsing this forum: No registered users and 58 guests
