Kohler 7.5 EKD generator over voltage fault
- dwhite
- Vessel Info: 1988 Carver 4207
1999 Boston Whaler Dauntless 14 / 75 Etec
Lake of the Woods Ontario - Location: Lake of the Woods Canada
When it was restarted, it ran for 10 seconds or so the voltage showed as high as 190 V
- Been thanked: 654 times
Re: Kohler 7.5 EKD generator over voltage fault
- dwhite
- Conquest
- Vessel Info: 2013 Boston Whaler Conquest 285
- Conquest
7.5EKD generator over voltage fault.
I don't think this model has a silicone controlled rectifier.
I replaced the voltage regulator/rectifier with a Chinese knock off.
It worked at home for the test then didn't work when I got out on the water. I checked the brushes because the manual mentioned brush arcing can lead to faulty regulator and or ADC main controller but the brushes look good.
I just replaced the regulator again but this time with a OEM part and this time I installed the supplied ground wire with the original ground also. It worked at home. I can't say I will be surprised if its another jinx and fails when I want to use it again but I will be hot!
This generator has 12 hours on it, I got it with 9. It's been a pain in the ass.
Fuel filter and fuel line issue, crank positioning sensor failure and replacement, remote digital gauge failure and replacement.
Now overvoltage faulting
If it wasn't so hard to get to and get out I turn it into an artificial reef.
The cost of the ADC2 is 2K so I'm trying to avoid that if I can.
- dwhite
Also try contacting SMD in Orillia Ontario, they've been in generator repairs for years and may have a used/parted unit lying around.... https://www.smdservices.ca/
- dwhite
Had I not removed the generator from the boat to preform a few test which were too difficult to preform while installed on the boat, there could have been a disaster if the last bolt holding the stator on the block had let go.
- waybomb
- CYO Moderator
- Been thanked: 490 times
- dwhite
